LPCXpresso 'Manage linker script' feature / bug
Content originally posted in LPCWare by Ex-Zero on Fri Apr 27 10:28:16 MST 2012
Every time I copy a (cleaned) project and rename it, linker script file names (*.ld) are not updated :mad:
My workaround is to disable 'Manage linker script', clean my project and reenable 'Manage linker script' again :rolleyes:
Now new linker script files are generated and I can delete the old ones :)
Is this a feature, a bug or am I just too dump to find an 'Automatic linker script file Update' button?
Content originally posted in LPCWare by CodeRedSupport on Thu Sep 20 05:44:22 MST 2012
Yes, still on the list.
CodeRedSupport
Content originally posted in LPCWare by Ex-Zero on Thu Sep 20 05:20:42 MST 2012
Quote: CodeRedSupport
...it is on the list of things to be looked at for a future release...
CodeRedSupport
Just tested V4.3.0 without success :(
Is this issue still on the list :confused:
Content originally posted in LPCWare by Ex-Zero on Fri Apr 27 13:15:45 MST 2012
Good to know, thanks :)
Content originally posted in LPCWare by CodeRedSupport on Fri Apr 27 12:54:33 MST 2012
Zero - you're right. I've hit this caching issue myself and it is on the list of things to be looked at for a future release. Your workaround is the simplest one that I am aware of.
PS - Hello Larry - it's been a while!
CodeRedSupport
Content originally posted in LPCWare by larryvc on Fri Apr 27 11:01:30 MST 2012
"dumb" not "dump".  You can be the former, you can take the latter. :rolleyes:
I would say it is a bug or an undesirable feature. :)  I'm back...
