LPCXpresso 7.7.2 - Modifying PIN value or Direction Error
858 次查看
Content originally posted in LPCWare by Carl-CircuitWorx on Mon Apr 20 04:58:19 MST 2015
Using the latest LPCXpresso, when I manually change the value of a PIN via the memory tab opened by the Peripherals+ view I get the following error :
33: Unknown register in register modify GPIO-PORT.PIN-0-.PORT12
Same error when trying to modify a direction value via the DIR register
Using an LPC1549, debugger is paused.
846 次查看
Content originally posted in LPCWare by Carl-CircuitWorx on Mon Apr 20 09:27:03 MST 2015
Glad I can help :)
Carl.
846 次查看
Content originally posted in LPCWare by lpcxpresso-support on Mon Apr 20 08:21:27 MST 2015
We have reproduced the problem and are investigating.
Thanks for the problem report and sorry for the inconvenience.
