LPCXPresso has stopped working
2,323 次查看
Content originally posted in LPCWare by ozenozkaya on Tue Jul 16 01:11:48 MST 2013
When starting LPCXPresso IDE, firstly it asks for workspace and when I choose workspace it opens for 1 or 2 seconds. But after 2 seconds IDE colses itself by error: "lpcxpresso.exe has stopped working". I have attached the error screen.
My IDE version is v 5.2.6_2137
I am using Windows 7 Home Basic 64-bit.
How can I get LPCXpresso IDE working?
10 回复数
2,288 次查看
Content originally posted in LPCWare by ozenozkaya on Wed Nov 20 04:49:55 MST 2013
I am sorry for misunderstanding. All of the installation is located below C:/nxp/
2,288 次查看
Content originally posted in LPCWare by lpcxpresso-support on Wed Nov 20 02:46:43 MST 2013
I asked where on YOUR system you have installed LPCXpresso - i.e. which directory?
2,288 次查看
Content originally posted in LPCWare by ozenozkaya on Wed Nov 20 02:16:57 MST 2013
I am using Windows 7 Home Basic 64-bit SP1. I installed LPCXpresso directly from "http://www.lpcware.com/lpcxpresso/download".
2,288 次查看
Content originally posted in LPCWare by lpcxpresso-support on Wed Nov 20 01:46:10 MST 2013
Which Operating System are you using (including service pack level).
Where have you installed LPCXpresso?
2,288 次查看
Content originally posted in LPCWare by ozenozkaya on Wed Nov 20 01:08:56 MST 2013
My error stil continues although I updated java to latest version. Here below you can find my log.
!SESSION 2013-11-09 10:44:08.719 -----------------------------------------------
eclipse.buildId=unknown
java.version=1.7.0_25
java.vendor=Oracle Corporation
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=en_US
Framework arguments:  -application org.eclipse.help.base.helpApplication
Command-line arguments:  -application org.eclipse.help.base.helpApplication -data C:\nxp\LPCXpresso_6.1.0_164\lpcxpresso\workspace
!ENTRY org.eclipse.equinox.p2.reconciler.dropins 4 0 2013-11-09 10:44:13.027
!MESSAGE FrameworkEvent ERROR
!STACK 0
org.osgi.framework.BundleException: Exception in org.eclipse.equinox.internal.p2.reconciler.dropins.Activator.start() of bundle org.eclipse.equinox.p2.reconciler.dropins.
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.startActivator(BundleContextImpl.java:734)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.start(BundleContextImpl.java:683)
at org.eclipse.osgi.framework.internal.core.BundleHost.startWorker(BundleHost.java:381)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.resume(AbstractBundle.java:390)
at org.eclipse.osgi.framework.internal.core.Framework.resumeBundle(Framework.java:1176)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.resumeBundles(StartLevelManager.java:559)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.resumeBundles(StartLevelManager.java:544)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.incFWSL(StartLevelManager.java:457)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.doSetStartLevel(StartLevelManager.java:243)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.dispatchEvent(StartLevelManager.java:438)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.dispatchEvent(StartLevelManager.java:1)
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230)
at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:340)
Caused by: java.lang.IllegalStateException: Profile profile is not current. Expected timestamp 0 but was 0.
at org.eclipse.equinox.internal.p2.engine.SimpleProfileRegistry.lockProfile(SimpleProfileRegistry.java:758)
at org.eclipse.equinox.internal.p2.engine.Engine.perform(Engine.java:67)
at org.eclipse.equinox.internal.p2.engine.Engine.perform(Engine.java:44)
at org.eclipse.equinox.internal.p2.reconciler.dropins.ProfileSynchronizer.executePlan(ProfileSynchronizer.java:781)
at org.eclipse.equinox.internal.p2.reconciler.dropins.ProfileSynchronizer.performAddRemove(ProfileSynchronizer.java:188)
at org.eclipse.equinox.internal.p2.reconciler.dropins.ProfileSynchronizer.synchronize(ProfileSynchronizer.java:127)
at org.eclipse.equinox.internal.p2.reconciler.dropins.Activator.synchronize(Activator.java:461)
at org.eclipse.equinox.internal.p2.reconciler.dropins.Activator.start(Activator.java:176)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl$1.run(BundleContextImpl.java:711)
at java.security.AccessController.doPrivileged(Native Method)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.startActivator(BundleContextImpl.java:702)
... 12 more
Root exception:
2,288 次查看
Content originally posted in LPCWare by lpcxpresso-support on Fri Jul 19 01:00:59 MST 2013
How are you trying to run LPCXpresso? It looks like you are trying to run the help application.
2,288 次查看
Content originally posted in LPCWare by serge on Fri Jul 19 00:02:01 MST 2013
I think Java is at the origin of your problem. I see that you have an old version of Java (1.6). This version has a lot of issues especialy concerning safety.
You should upgrade to version 7 (1.7)
HTH
Serge
2,288 次查看
Content originally posted in LPCWare by ozenozkaya on Thu Jul 18 17:59:20 MST 2013
You are welcome :) I can beleive that we can surpass this error. Here below you can find the log
!SESSION 2013-07-16 00:40:41.405 -----------------------------------------------
java.version=1.6.0_45
java.vendor=Sun Microsystems Inc.
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=tr_TR
Command-line arguments:  -application org.eclipse.help.base.helpApplication -data C:\nxp\LPCXpresso\lpcxpresso\workspace
!ENTRY org.eclipse.equinox.p2.reconciler.dropins 4 0 2013-07-16 00:40:45.061
!STACK 0
Caused by: java.lang.IllegalStateException: Profile profile is not current. Expected timestamp 1373951444488 but was 1373951444488.
at org.eclipse.equinox.internal.p2.reconciler.dropins.ProfileSynchronizer.setProperty(ProfileSynchronizer.java:764)
at org.eclipse.equinox.internal.p2.reconciler.dropins.ProfileSynchronizer.synchronize(ProfileSynchronizer.java:113)
... 12 more
Root exception:
2,288 次查看
Content originally posted in LPCWare by ozenozkaya on Thu Jul 18 17:57:43 MST 2013
Here below my log file:
!STACK 0
... 12 more
Root exception:
2,288 次查看
Content originally posted in LPCWare by lpcxpresso-support on Tue Jul 16 04:07:14 MST 2013
I am sorry for the problems you are experiencing.
We have never seen this error before, but unfortunately, we do not have Windows 7 Home Basic 64 bit available to test.
Could locate the file <your workspace>/.metadata/.log and post it to the forum.
Also, do you have another computer available to try it on?
