LPC17xx, sleep modes and reprogramming the flash
Content originally posted in LPCWare by micronpn on Sat Apr 17 04:12:46 MST 2010
When LPC17xx (LPC1754 in my application) goes in a low power mode is impossible to reprogram the flash memory via jtag using LpcXpresso 3.2.3.
I made some checks and I found that the reset pin timing is critical, in my application I have a 5 seconds delay before the mcu goes in deep power down so I may manually reset my board and I force reset active until jtag starts to connect to the mcu so I am able to program the mcu. Without 5 seconds delay could be impossible to reprogram a mcu if it is in power down modes. May I hope that some one correct the reset pin management in LpcXpresso IDE to apply a 1 second reset signal and then activate the normal flash programming procedure?
Content originally posted in LPCWare by renan on Thu Apr 22 08:51:20 MST 2010
You could use RDB1768 from Code Red.
I'm using it.
Renan
Content originally posted in LPCWare by mayotte1 on Thu Apr 22 07:42:34 MST 2010
I would like to get a lpc17xx board that worked with the lpcxpresso link. What board did you use?
