LPC17xx MCPWM register missing
1,130 次查看
Content originally posted in LPCWare by martinho on Wed Apr 20 06:20:17 MST 2011
I'm missing the MCPWM Registers (Motor Control PWM) in the Peripherals view, I know i can watch directly the memory at 0x400B800, but this is not very intuitive to use. Would it be possible to add this in the next release?
Edit: Strangely the access seems not to work neither for the MCPWM not for the QEI peripherals (I hope they are present on my chip (LPC1752), I did not find any hint that they are present only on some chip's).
Edit Edit: I had disabled the QEI and MCPWM modules, for this reason i got errors when trying to monitor the Address 0d 0x400B800, this is now working, remains the problem with the missing MCPWM in the Peripherals view.
Martin
1,071 次查看
Content originally posted in LPCWare by martinho on Wed Apr 20 10:45:49 MST 2011
Quote: larryvc
I have reported this to CodeRed Support.
Larry
Thank's a lot Larry!
Martin
1,071 次查看
Content originally posted in LPCWare by larryvc on Wed Apr 20 10:13:45 MST 2011
Larry
1,071 次查看
Content originally posted in LPCWare by Polux rsv on Wed Apr 20 07:51:09 MST 2011
Reads the errata sheets. I remember something is not working for motor control on one or more LPC17xx devices.
Angelo
