LPC1769 error reported
3,584件の閲覧回数
sebastianbarcia
I was debugging a project of lpc1769 with lpcxpresso and show me the follow code error. Is the microcontroller dead?
How can i fix it?
ラベル(3)
3 返答(返信)
3,315件の閲覧回数
lpcxpresso_supp
Have you ever been able to debug your system? If so what changed, or what code did you program into the MCU, before it stopped working?
Is this an off-the-shelf board, or your own board?
If your own board, please check out - https://community.nxp.com/message/630601
What debug probe are you using?
What version of LPCXpresso IDE are you using? And on what host OS ?
Please also double check that you following the process for booting the chip into ISP mode correctly - you must be pulling the ISP pin as the board is reset/powered up.
LPCXpresso Support
3,315件の閲覧回数
lpcxpresso_supp
In the first place, see :https://community.nxp.com/message/630748
LPCXpresso Support
3,315件の閲覧回数
sebastianbarcia
Thanks for your reply
None of that worked
I can not erase the flash
Mode ISP not response
