LPC1769 Start
LPC1769 Start
1,743 次查看
lpcware
Content originally posted in LPCWare by drvrh on Wed Feb 27 05:18:44 MST 2013
Hello all;
i would like turn on LED on LPC1769Xpresso board, but I have a bad knowledge for programing with a LPC.
Maybe who have example code for LED blink, and basic schematics to see where connect LED.
I see on LPCXpresso support web page project LPCXpresso Blinky Example Project for LPC1102 with ISP. If I can flashing this program on my LPC1769Xpresso board.
Thank's for answer.
Sorry for my bad English.
5 回复数
1,581 次查看
lpcware
Content originally posted in LPCWare by studyembedded on Mon Mar 04 19:16:05 MST 2013
check this site
http://www.zembedded.com/category/arm-2/?viewall
I found few very info motive tutorial here...best of luck!
1,581 次查看
lpcware
Content originally posted in LPCWare by drvrh on Wed Feb 27 09:15:33 MST 2013
Thank you,
but I like see which pin-s using for blinking LED, in GPIO header file is statement:
static LPC_GPIO_TypeDef (* const LPC_GPIO[4]) = { LPC_GPIO0, LPC_GPIO1, LPC_GPIO2, LPC_GPIO3 };
if I correct understand this, mean, on this pin 0.0, 0.1, 0.2 and 0.3, control state?
And this.: :D,
how connect LED on this pin-s with resistor or no? Have a internal pull-up resistor? Where in code is turn-on pull-up resistor?
If this GPIO TTL or CMOS level?
And for this working, must be added header file for LPC17xx, and added Core CM3.
1,581 次查看
lpcware
Content originally posted in LPCWare by TheFallGuy on Wed Feb 27 08:58:25 MST 2013
Nothing
1,581 次查看
lpcware
Content originally posted in LPCWare by drvrh on Wed Feb 27 08:44:59 MST 2013
Ok, and what I change in this Example for working with LPC1796?
1,581 次查看
lpcware
Content originally posted in LPCWare by TheFallGuy on Wed Feb 27 07:09:01 MST 2013
There is an example shipped in the product that does this for LPC1769.
If you want to see how to load the examples, read the Getting Started guide.
