LPC1769 Set date and time
3,330件の閲覧回数
Content originally posted in LPCWare by arturn on Thu May 30 09:49:13 MST 2013
I would like to sync date and time to LPC1769 board, because every timethat I disconnect board, I lost current date.
At boot time call to webserver to get current date, and set this to LPC_RTC structure with below code :
[FONT=Courier New][SIZE=2]
void SetStrTime(char * StrTime)
    char year[4];
    char month[2];
    char day[2];
    char minute[2];
    char hour[2];
    char second[2];
    strncpy(year,StrTime,4);
    StrTime+=5;
    strncpy(month,StrTime,2);
    StrTime+=3;
    strncpy(day,StrTime,2);
    StrTime+=3;
    strncpy(hour,StrTime,2);
    StrTime+=3;
    strncpy(minute,StrTime,2);
    StrTime+=3;
    strncpy(second,StrTime,2);
    StrTime+=3;
    LPC_RTC->YEAR = atoi(year);
    LPC_RTC->MONTH = atoi(month)+1;
    LPC_RTC->DOM = atoi(day) +1;
    LPC_RTC->HOUR = atoi(hour);
    LPC_RTC->MIN = atoi(minute);
    LPC_RTC->SEC = atoi(second);
}[/SIZE][/FONT]
This code runs well, but board "hangs out" after call...
Should I reboot board after set date?
Can date change affect to running tasks ? I set at start-up there isn't other runnig tasks...
How Can I reboot board by code?
Thanks!
12 返答(返信)
3,216件の閲覧回数
Content originally posted in LPCWare by ToBeFrank on Fri May 31 07:15:08 MST 2013
Quote: arturn
Finally I fix '\0' bug and code runs well...
It's still wrong.
    char year[4];
    year[4]='\0';
3,216件の閲覧回数
Content originally posted in LPCWare by ToBeFrank on Fri May 31 07:11:47 MST 2013
Quote: kabriolin
Something hurt me:
char year[[B]4[/B]];
    char month[[B]2[/B]];
    char day[[B]2[/B]];
char minute[[B]2[/B]];
    char hour[[B]2[/B]];
    char second[[B]2[/B]];
year[[B]4[/B]]='\0';
month[[B]2[/B]]='\0';
I think you meant:
char year[[B]5[/B]];
year[4]=0;
3,216件の閲覧回数
Content originally posted in LPCWare by R2D2 on Fri May 31 04:36:02 MST 2013
Quote: arturn
Sorry.. I'm newby...
Where and How I should perform setup clock?
I'm completly lost... :S
UM10360 is your friend. Read it:
Quote:
27.6.2.2 Clock Control Register (CCR - 0x4002 4008)
The clock register is a 4-bit register that controls the operation of the clock divide circuit. Each bit of the clock register is described in Table 509. [COLOR=Red]All NC bits in this register should be initialized when the RTC is first turned on.[/COLOR]
Table 509. Clock Control Register (CCR - address 0x4002 4008) bit description
Bit Symbol Value Description Reset value
0 CLKEN Clock Enable.
   [COLOR=Red] 1 The time counters are enabled.[/COLOR]
    0 The time counters are disabled so that they may be initialized.
3,216件の閲覧回数
Content originally posted in LPCWare by arturn on Fri May 31 04:24:44 MST 2013
Quote: stalisman
I don't think he got it  :-)
I solved... what a disaster!!!!!
Now It's sems to work... !
3,216件の閲覧回数
Content originally posted in LPCWare by arturn on Fri May 31 04:11:43 MST 2013
3,216件の閲覧回数
Content originally posted in LPCWare by stalisman on Fri May 31 04:11:33 MST 2013
Quote: kabriolin
Something hurt me:
    char day[[B]2[/B]];
3,216件の閲覧回数
Content originally posted in LPCWare by R2D2 on Fri May 31 03:38:57 MST 2013
Quote: arturn
But now clock its stopped... Always return the same time.. :S
Where's your setup? Your clock doesn't know that you want to run it :)
3,216件の閲覧回数
Content originally posted in LPCWare by kabriolin on Fri May 31 03:30:09 MST 2013
Something hurt me:
    char day[[B]2[/B]];
3,216件の閲覧回数
Content originally posted in LPCWare by arturn on Fri May 31 01:57:21 MST 2013
    char year[4];
    char month[2];
    char day[2];
    char minute[2];
    char hour[2];
    char second[2];
    year[4]='\0';
    StrTime+=5;
    month[2]='\0';
    StrTime+=3;
    day[2]='\0';
    StrTime+=3;
    hour[2]='\0';
    StrTime+=3;
    minute[2]='\0';
    StrTime+=3;
    second[2]='\0';
    StrTime+=3;
    LPC_RTC->DOM = atoi(day);
void GetStrTime(char * StrTime)
    STRCLEAN(StrTime);
    sprintf(StrTime,"%04i-%02i-%02iT%02i:%02i:%02i",LPC_RTC->YEAR,LPC_RTC->MONTH - 1,LPC_RTC->DOM,LPC_RTC->HOUR,LPC_RTC->MIN,LPC_RTC->SEC);
3,216件の閲覧回数
Content originally posted in LPCWare by ToBeFrank on Thu May 30 13:18:49 MST 2013
You're free to waste your time looking elsewhere, but I suggest you fix this bug first. From the strncpy documentation:
Quote:
No null-character is implicitly appended at the end of [I]destination[/I] if [I]source[/I] is longer than [I]num[/I]. Thus, in this case, [I]destination[/I] shall not be considered a null terminated C string (reading it as such would overflow).
What do you think atoi is doing with your not null terminated strings?
3,216件の閲覧回数
Content originally posted in LPCWare by arturn on Thu May 30 13:12:29 MST 2013
I'm not sure that this is the reason...
Structure fields are setting right...
3,216件の閲覧回数
Content originally posted in LPCWare by ToBeFrank on Thu May 30 10:30:29 MST 2013
You don't have a null at the end of your char arrays. Thus, atoi is failing.
