LPC1768 interrupt time waste
Content originally posted in LPCWare by AmirHejazi on Fri Oct 04 01:15:58 MST 2013
hi
is it possible to define amount of clock pulses used(consumed) in every interrupt?(assume that the handler does not contain any code)
Content originally posted in LPCWare by TheFallGuy on Fri Oct 04 03:37:42 MST 2013
If you read the PDF file that I provided the link to, then it explains everything. Read the section on the NVIC.
Content originally posted in LPCWare by AmirHejazi on Fri Oct 04 03:33:40 MST 2013
thanks
1- is it a fixed value or it's the max value of latency?
2- 12 cycles for push the handler and 12 cycles for pop from it. (page 7)
that means a simple interrupt hendler consumes 24 clock pulses. per every call.
Did i said that correctly?
best regards
Amir
Content originally posted in LPCWare by TheFallGuy on Fri Oct 04 03:01:16 MST 2013
According to this:
http://www.arm.com/files/pdf/introToCortex-M3.pdf
the interrupt latency of a Cortex-M3 is 12 cycles (compared with 24-42 for ARM7TDMI).
