LPC1343, problem with UART, simultaneous reception and transmission.
1,586件の閲覧回数
Content originally posted in LPCWare by LPC_Sk on Thu May 03 17:48:10 MST 2012
Thank you! Regards!
6 返答(返信)
1,579件の閲覧回数
Content originally posted in LPCWare by LPC_Sk on Fri May 04 09:38:21 MST 2012
Anyone have experience in UART communication simultaneously?
1,579件の閲覧回数
Content originally posted in LPCWare by Ex-Zero on Fri May 04 07:27:02 MST 2012
Quote: LPC_Sk
Do not use LPCXpress,if not Keil. But that's not important....
Thanks for getting the audience in fits :)
Quote: LPC_Sk
...what matters is the logic.
So is your logic already volatile?
1,579件の閲覧回数
Content originally posted in LPCWare by LPC_Sk on Fri May 04 06:34:28 MST 2012
Do not use LPCXpress,if not Keil. But that's not important, what matters is the logic.
1,579件の閲覧回数
Content originally posted in LPCWare by ex-kayoda on Fri May 04 04:19:02 MST 2012
Quote: LPC_Sk
Attached project.
Sorry, can't import this in my LPCXpresso :confused:
I guess this project is not generated with LPCXpresso?
1,579件の閲覧回数
Content originally posted in LPCWare by LPC_Sk on Fri May 04 04:07:53 MST 2012
Thank you! Regards!
1,579件の閲覧回数
Content originally posted in LPCWare by ex-kayoda on Fri May 04 01:41:29 MST 2012
Quote: LPC_Sk
Some solution?
It's difficult to test / verify your problem without your code :(
So please export and post a complete project.
Now a wild guess: I'm missing some volatiles in your code :confused:
See: http://support.code-red-tech.com/CodeRedWiki/CompilerOptimization?highlight=%28volatile%29
