LPC1114: Not able to write to flash memory using IAP commands
924件の閲覧回数
Content originally posted in LPCWare by abhilash.bidari on Tue Mar 20 10:03:13 MST 2012
controller: LPC1114
Iam trying to write the data to the flash using the IAP command. But iam not able to write the data. When i tried to write data, i got the return value as "13". Which means ADDRESS_ERROR ->Address is not on word boundary.
So please any one help me out.
Iam trying to write the data to the location:"0x00007000"
Good news is Iam able to erase.
901件の閲覧回数
Content originally posted in LPCWare by abhilash.bidari on Tue Mar 20 22:51:21 MST 2012
Sorry prob has been solved.
I was giving the wrong data size for  copy ram to flash command.
It after giving proper size it is working fine
901件の閲覧回数
Content originally posted in LPCWare by gbm on Tue Mar 20 12:03:34 MST 2012
So, what is your question? You've got the precise description of your error - correct the problem.
