Issue with forum searching?
lpcware
Content originally posted in LPCWare by anomaly256 on Sat Aug 21 06:01:58 MST 2010
Regardless of what search I Try, I get 0 results.  Even when I know for a fact the search terms exist in both thread titles and posts within those threads.  :(
Although I enjoy reading all the posts here to find little nuggets of information it does make it hard to search for specific things.  Seems to have been broken for the 2 weeks I've had my lpc1768 lpcxpresso board so I guess no one else has noticed/reported this yet?
Or maybe I'm the only one experiencing this problem?
Cheers
lpcware
Content originally posted in LPCWare by anomaly256 on Sat Aug 28 02:15:17 MST 2010
@CodeRedSupport:  yep, got it, thanks.  Just wanted to give an example to replicate the issue.
@Igorsk: Ahh right, that would explain it then, cheers.
(if any board administrators are reading, maybe it'd be helpful to highlight that the minimum search term length is 4, or maybe set it to 3 if it's not too much of a burden on the db)
lpcware
Content originally posted in LPCWare by igorsk on Mon Aug 23 06:05:41 MST 2010
Default minimum indexable word length for vBulletin is 4 letters, that's the reason why "usb" is not found. It can be changed.
lpcware
Content originally posted in LPCWare by CodeRedSupport on Mon Aug 23 05:54:58 MST 2010
Ironically the issue of forum searching has come up before ....
"Forum search fails for me. Is it working for you?"
http://knowledgebase.nxp.com/showthread.php?p=1216
This previous thread was also based on a search for the term "usb" failing.
lpcware
Content originally posted in LPCWare by CodeRedSupport on Sun Aug 22 23:37:19 MST 2010
As mentioned above. try using google:
http://www.google.co.uk/search?q=site%3Aknowledgebase.nxp.com+usb&ie=utf-8&oe=utf-8&aq=t&rls=org.moz...
lpcware
Content originally posted in LPCWare by anomaly256 on Sat Aug 21 17:28:33 MST 2010
http://knowledgebase.nxp.com/search.php?do=process&query=USB
The following errors occurred with your search:
[LIST=1]
[*]Sorry - no matches. Please try some different terms.
[/LIST]
lpcware
Content originally posted in LPCWare by anomaly256 on Sat Aug 21 17:22:57 MST 2010
Ahh thanks CodeRedSupport.
That'll do (although maybe it'll lag behind a little?)
Still curious why I'm having this problem though
lpcware
Content originally posted in LPCWare by CodeRedSupport on Sat Aug 21 06:23:15 MST 2010
I use google:
site:knowledgebase.nxp.com my search term
Works wonders!
lpcware
Content originally posted in LPCWare by Ex-Zero on Sat Aug 21 06:14:35 MST 2010
Sorry to say that, I've no problem with Thread Search or Post Search :(.
