Content originally posted in LPCWare by robert.berger on Mon May 23 10:14:09 MST 2011
I am able to compile and flash the LPCXpresso1769 through the Code Red IDE using the debugger.
When I disconnect from the debugger the software is supposed to be still inside the processor, it's just not running without the debugger attached. I would like something that runs stand alone.
Is it just a matter of building a non debug version and flashing it?
Robert
