Interface external SPI flash with LPC1114
1,514 次查看
Content originally posted in LPCWare by vineetrvce on Tue Jun 26 00:30:43 MST 2012
Hello Group,
   Has anyone interfaced the SPI Flash memory (say, 8Mbit) with LPC 111x CPU.
If there is any reference code, please advise.
Vineet.
1,462 次查看
Content originally posted in LPCWare by Polux rsv on Tue Jun 26 02:47:07 MST 2012
Researchinnovation,
He was not looking for user manuals, but for example code to read Flash memory through SPI. :rolleyes:
vineetrvce,
There are various SPI flash families, with different protocols: 25Pxx, AT45xxx,.... What is your device?
You will find lot of code. Even if it is for other micros, they will be good starting points.
Angelo
1,461 次查看
Content originally posted in LPCWare by researchinnovation on Tue Jun 26 02:06:21 MST 2012
Quote: vineetrvce
Hello Group,
Vineet.
Hi...!!!
http://www.lpcware.com/content/nxpfile/um10398-lpc111xlpc11cxx-user-manual-0
http://www.radiolocman.com/datasheet/data.html?di=114799&/LPC1113FHN33
http://www.scribd.com/doc/77048166/ARM-MCU-User-manual-lpc11xx-lpc11cxx
Thanks & Regards....:)
