Content originally posted in LPCWare by jdurand on Wed Jun 13 22:53:58 MST 2012
I used to be able to use instruction stepping, but now it's grayed out. I can single step code just fine, I can view the disassembly, i just can't get back to where I can step through the disassembly.
Using LPCXpresso v4.2.3 on Ubuntu Precise.
Problem shows up with an LPC1113 board I designed and is now in production, using Red Probe+.
Also shows up on LPC-Link card for LPC1769 using the built-in probe.
