Installing LPCxpresso in other Computer
Content originally posted in LPCWare by silvioanton on Wed Oct 16 19:49:08 MST 2013
Hi.
I am going to purchase a new computer and I would like to know if I can install the LPCxpresso again in my new computer with the same activation code or do I need to purchase the programme again. Thank you.
Content originally posted in LPCWare by lpcxpresso-support on Thu Oct 17 02:19:07 MST 2013
Assuming that you are using the Free Edition, you simply need to install LPCXpresso on the new computer and then go through the activation process again (ie create a new serial number, and use this to generate a new activation code for your new machine).
If you are use the Pro Edition, then you need to deactive your license on your old computer. Then go through the activation process again, using the same activation code.
LPCXpresso Support
