I can't debug code with LPC11U35 and LPC-Link
2,413件の閲覧回数
Content originally posted in LPCWare by jverasay on Wed Jun 15 07:39:29 MST 2016
Hi All,
I wanted to ask you about this problem that I'm having. Basically, I'm working with a LPC11U35 which is a develpment kit from Embedded Artists and I'm using a LPC-Link to debug my code.
I was able to use and work with both of them but suddenly it stop working. Let me show you the error that I'm getting.
Screenshot is also attached.
Error in final launch sequence
Error: Error reported by server (redlinkserv.exe):
Status fail
LinkServer has been terminated and will be restarted.
Please restart your debug session.
If the problem recurs, please power cycle your debug probe and restart LPCXpresso.
Status fail
Let me enumerate what I made to fix the problem but I couldn't.
1- Uninstall the drivers and re-install them.
2- I tried with differents USB ports
3- I've installed in a new PC the toolchain and I've set my project from the scratch but it didn't work neither.
4- I've loaded a binary without usint the debugguer and it worked! So, that make me suspect that the problem is on the LPC-Link board.
Can anyone help me on this?? I don't know what to do.
Thanks in advance.
Regards.
タグ(2)
2,203件の閲覧回数
bump
2,203件の閲覧回数
lpcxpresso_supp
Hi jverasay,
From the information supplied it is hard to know what has occurred.
Please can respond including your debug log The Debug Log  and similarly the redlink|linkserver log.
Yours,
LPCXpresso-Support
