How to test UART program using LPC xpresso?
Content originally posted in LPCWare by sravansreeram on Mon Jun 22 02:38:26 MST 2015
Hi all,
I'm quite new to this, I am using LPC1347 expresso board and lpcopen libraries. I want to test and check the UART program from the LPC open libraries (periph_uart_rb) .
I have little knowledge about gtkterm in ubuntu.
I have set up gtk term with same baud rate as it is in the C code but the message is not being transmitted and received.
Can someone help me out with this?
Content originally posted in LPCWare by sravansreeram on Tue Jun 23 22:38:53 MST 2015
Thanks a lot! I tried it and UART is working now.
Content originally posted in LPCWare by elektronist on Mon Jun 22 06:09:36 MST 2015
I recommend you to use cutecom.
