How to get hex file using LPC-Link 2 from LPC812 Flash memory.
840 次查看
lpcware
Content originally posted in LPCWare by wayne.jeong on Mon Oct 20 05:25:19 MST 2014
Hello.
I am developing new project using LPC812.
If I want to get hex file from LPC812 flash memory, can I get the file using LPC-Link2?
Thank you.
781 次查看
lpcware
Content originally posted in LPCWare by lpcxpresso-support on Mon Oct 20 05:48:00 MST 2014
If you are debugging your application, you can use the Memory view, "Traditional" rendering to Export to a file. Text, Binary and SRecord are the supported formats.
http://www.lpcware.com/content/faq/lpcxpresso/import-export-memory
