How to create Smart Update liblinks.xml?
897 次查看
lpcware
Content originally posted in LPCWare by LabRat on Mon Mar 31 03:17:36 MST 2014
I'm trying to use Smart update, but there are no xml-files included in LPCOpen.
I know that project wizard is generating this file. But obviously they were deleted...
How do I generate this file for all forgotten LPCOpen libraries?
Note: Copy/Paste/Edit this file is working, but not very smart...
855 次查看
lpcware
Content originally posted in LPCWare by lpcxpresso-support on Mon Mar 31 18:03:54 MST 2014
The LPCOpen libraries aren't quite created in this way, which is probably the reason as to why the liblinks.xml files aren't in the library projects. However I agree that they should be, and will follow this up with the LPCOpen team.
LPCXpresso Support
