How to compile only certain folders
1,046 次查看
massimocristofo
Hi, everyone!
I have this folders tree in my project
  • PROJECT
    • inc
    • src
      • src1
      • src2
I want LPCXpresso to compile only inc and src/src2 folders, ignoring src/src1. Also I DON'T want to delete src/src1 from disk.
How to achieve this?
Thanks!
MIX
947 次查看
thefallguy
Right-click on the file or folder you want to exclude, and from the pop-up menu, select Resource Configuration->Exclude from build. You can then choose which build configuration to exclude from.
948 次查看
thefallguy
947 次查看
massimocristofo
Exactly what I need. Thanks!
