Help for CAN programming on LPC11C24
856件の閲覧回数
lpcware
Content originally posted in LPCWare by Ankit on Thu Aug 23 04:02:39 MST 2012
Hii,
I have started using LPC11C24. I want to send/receive data from on-chip CAN tranceiver but I am confused how to use available CAN library. Please someone  help in this issue and provide me the steps to program for CAN communication.
2 返答(返信)
785件の閲覧回数
lpcware
Content originally posted in LPCWare by NXP_Europe on Sat Aug 25 12:42:39 MST 2012
Hi anki,
I can imagine that programming the CAN part of e.g. the lpc11c24 is not easy.
But others have solved that problem for you ...
see:
http://knowledgebase.nxp.com/showthread.php?t=2426&highlight=11c24&page=3
see also:
http://ics.nxp.com/support/lpcxpresso/
785件の閲覧回数
lpcware
Content originally posted in LPCWare by Ex-Zero on Thu Aug 23 05:04:33 MST 2012
You're late ;)
This issue has been discussed several times before. So just use 'Sticky' thread above ("Searching the LPCXpresso Forum and Code Red's FAQ site") to search this forum for LPC11C24, LPC11C14 CAN onchip questions :)
