GCC newest release
GCC newest release
719件の閲覧回数
Content originally posted in LPCWare by micronpn on Tue May 11 10:30:41 MST 2010
Is there any trouble/problem to manually change the GCC compiler (i.e. changing the pointing directories of the IDE) and use a different GCC release then 4.3.3?
Or in alternative may be possible manually substitute GCC bins in lpcxpresso path?
704件の閲覧回数
Content originally posted in LPCWare by CodeRedSupport on Tue May 11 11:09:42 MST 2010
As stated in http://knowledgebase.nxp.com/showthread.php?t=182, we continue to evaluate new gcc builds on a regular basis, and it is likely that at some  point later this year we will produce a new release of the LPCXpresso IDE that encorporates a more recent version of gcc than the current 4.3.3. I cannot currently give  any timescales as to when this might be though.
In the meantime, you are quite at liberty to plug in your own version of gcc - though we obviously cannot provide you with any support in doing so.
CodeRedSupport
