Flash memory and Data memory
Content originally posted in LPCWare by karthik.s on Wed Aug 04 02:58:17 MST 2010
I am using LPC1114.After building the application the following statistics are displayed on the console window.
text       data        bss        dec        hex    filename
  23892         32       5358      29282       7262    SampleSPI.axf
What i understand is text section indicates the amount of memory occupied in Flash(32KB).
What about the amount of RAM occupied by the application code?
Is it (data+bss)??
Original Attachment has been moved to: 1100583_UART.zip
Content originally posted in LPCWare by CodeRedSupport on Wed Aug 04 03:40:50 MST 2010
http://knowledgebase.nxp.com/showthread.php?t=522
