Flash as EEPROM
Flash as EEPROM
1,145 次查看
lpcware
Content originally posted in LPCWare by Hubert Wu on Fri Mar 05 07:58:22 MST 2010
I would like to use the flash as EEPROM function. How can I do? Does any sample where I could get?
1,122 次查看
lpcware
Content originally posted in LPCWare by igorsk on Mon Mar 15 07:54:05 MST 2010
All flash is mapped to memory, uso you can just read it as normal memory.
1,122 次查看
lpcware
Content originally posted in LPCWare by Hubert Wu on Mon Mar 15 03:31:09 MST 2010
thank you for great support. there is only IAP sample i can get. does any sample code for Flash sector define and how to read out the flash data?
Hubert Wu
1,122 次查看
lpcware
Content originally posted in LPCWare by NXP_Europe on Tue Mar 09 08:32:33 MST 2010
Hi Hubert Wu,
This topic is also discussed here:
http://knowledgebase.nxp.com/showthread.php?t=158
The guys there did a nice job and they are sharing the code as well.
In the LPC111x user manual, look for IAP in Chapter 17.8, here all commands needed for IAP are described.
Kind regards,
