Find what is making my executable so large
lpcware
Content originally posted in LPCWare by tss on Tue May 31 08:18:31 MST 2016
Hello!
I have an executable that I'm building, but it has gotten quite large. I'm dynamically linking so it should only be linking things I'm using, but I would like to know what is being linked in that is using so much space.
Is there a command I can run or a tool I can use to inspect my LPC project and show me what is taking so much space?
lpcware
bump
lpcware
Content originally posted in LPCWare by tss on Tue May 31 09:14:07 MST 2016
Awesome, thanks everyone!
lpcware
Content originally posted in LPCWare by lpcxpresso-support on Tue May 31 08:24:51 MST 2016
In the first place see:
https://www.lpcware.com/content/faq/lpcxpresso/application-flash-ram-size
You may also find the Symbol Viewer useful :
https://www.lpcware.com/content/faq/lpcxpresso/symbol-viewer
LPCXpresso Support
lpcware
Content originally posted in LPCWare by vtw.433e on Tue May 31 08:23:10 MST 2016
Look in the map file (.map) that is generated by the linker. This shows everything that is linked into your application.
