Example showing EEprom programming via IAP LPC1317
Content originally posted in LPCWare by Deepak Bansal on Fri Oct 12 03:37:14 MST 2012
Any example showing mentioned function.
Content originally posted in LPCWare by tha on Fri Oct 12 14:37:49 MST 2012
The EEPROM commands are the same as the LPC11Axx.  The EEPROM app note, AN11073, is applicable to the LCP1317.
