Ethernet Strange Behaviour
lpcware
Content originally posted in LPCWare by nkarakotas on Fri Mar 15 23:19:50 MST 2013
Hi Guys,
Im facing a strange problem that I recently noticed. Here is what happens:
When I program my LPC1769 chip with the program and board resets while connected to power everything works OK.
Now when I remove power and try to ping the board is not responsive!
Apparently the driver drops the packets received as they contain errors.
Im very confused to what is causing this. I also have another program that uses the Ethernet DMA but works OK.
Is this a hardware or software problem? What do you thik>?
Nick
