Error message in the log file
kennakajima
To whom it may concern,
I have problem using LPCXpresso 8.2.0. Would anyone help me solving following problem?  I put my comments followed by “K.N>”.
SW used: LPCXpresso 8.2.0
OS: Windows 7 Professional 64bit
Microcomputer: LPC4370
K.N> When I started LPCXpresso, I’ve got following error message and the program was shut down.
“An error has occured. See the log file.
C:\Users\(User Name)\Documents\LPCXpresso_8.2.0_647\workspace\(Workspace)\.metadata\.log.”
The following message was added at the same time stamp when I opened the specified file:
!SESSION 2017-06-02 16:24:01.162 -----------------------------------------------
eclipse.buildId=unknown
java.version=1.8.0_65
java.vendor=Oracle Corporation
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=ja_JP
Command-line arguments: -os win32 -ws win32 -arch x86
!ENTRY org.eclipse.osgi 4 0 2017-06-02 16:24:06.685
!MESSAGE Application error
!STACK 1
java.lang.LinkageError: Error reading class bytes: org.eclipse.ui.internal.WorkbenchPlugin$4
                   at org.eclipse.osgi.internal.loader.classpath.ClasspathManager.findClassImpl(ClasspathManager.java:572)
                   at org.eclipse.osgi.internal.loader.classpath.ClasspathManager.findLocalClassImpl(ClasspathManager.java:540)
                   at org.eclipse.osgi.internal.loader.classpath.ClasspathManager.findLocalClass(ClasspathManager.java:527)
                   at org.eclipse.osgi.internal.loader.ModuleClassLoader.findLocalClass(ModuleClassLoader.java:324)
                   at org.eclipse.osgi.internal.loader.BundleLoader.findLocalClass(BundleLoader.java:327)
                   at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:402)
                   at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:352)
                   at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:344)
                   at org.eclipse.osgi.internal.loader.ModuleClassLoader.loadClass(ModuleClassLoader.java:160)
                   at java.lang.ClassLoader.loadClass(ClassLoader.java:357)
                   at org.eclipse.ui.internal.WorkbenchPlugin.initializeContext(WorkbenchPlugin.java:1329)
                   at org.eclipse.ui.internal.Workbench.initializeLazyServices(Workbench.java:2201)
                   at org.eclipse.ui.internal.Workbench.init(Workbench.java:1652)
                   at org.eclipse.ui.internal.Workbench.access$43(Workbench.java:1624)
                   at org.eclipse.ui.internal.Workbench$59.run(Workbench.java:2972)
Caused by: java.util.zip.ZipException: invalid distance too far back
                   at java.util.zip.InflaterInputStream.read(InflaterInputStream.java:164)
                   at org.eclipse.osgi.storage.bundlefile.ZipBundleEntry$ZipBundleEntryInputStream.read(ZipBundleEntry.java:156)
                   at org.eclipse.osgi.storage.StorageUtil.getBytes(StorageUtil.java:195)
                   at org.eclipse.osgi.storage.bundlefile.BundleEntry.getBytes(BundleEntry.java:94)
                   at org.eclipse.osgi.internal.loader.classpath.ClasspathManager.findClassImpl(ClasspathManager.java:568)
                   ... 14 more
K.N>Following message was also recorded at slightly earlier time stamp:
!SESSION 2017-06-02 11:00:00.020 -----------------------------------------------
!ENTRY org.eclipse.ui 4 4 2017-06-02 11:00:55.652
!MESSAGE Plugin org.eclipse.cdt.ui, extension org.eclipse.ui.decorators, id org.eclipse.cdt.internal.ui.CustomBuildSettingsDecorator: Duplicate id found: org.eclipse.cdt.internal.ui.CustomBuildSettingsDecorator
!ENTRY org.eclipse.ui 4 4 2017-06-02 11:00:55.683
!MESSAGE Plugin org.eclipse.cdt.ui, extension org.eclipse.ui.decorators, id org.eclipse.cdt.internal.ui.CustomBuildSettingsDecorator: Unknown extension tag found: decorator
!ENTRY org.eclipse.cdt.ui 4 0 2017-06-02 11:30:04.263
!MESSAGE Error in CDT UI during reconcile
!STACK 1
C Model Exception: C Model Status [Element (Project Name).c does not exist.]
                   at org.eclipse.cdt.internal.core.model.CElement.newNotPresentException(CElement.java:484)
                   at org.eclipse.cdt.internal.core.model.TranslationUnit.makeConsistent(TranslationUnit.java:573)
                   at org.eclipse.cdt.internal.core.model.ReconcileWorkingCopyOperation.executeOperation(ReconcileWorkingCopyOperation.java:62)
                   at org.eclipse.cdt.internal.core.model.CModelOperation.execute(CModelOperation.java:341)
                   at org.eclipse.cdt.internal.core.model.CModelOperation.run(CModelOperation.java:607)
                   at org.eclipse.cdt.internal.core.model.CModelOperation.runOperation(CModelOperation.java:635)
                   at org.eclipse.cdt.internal.core.model.WorkingCopy.reconcile(WorkingCopy.java:362)
                   at org.eclipse.cdt.internal.ui.text.CReconcilingStrategy.reconcile(CReconcilingStrategy.java:78)
                   at org.eclipse.cdt.internal.ui.text.CReconcilingStrategy.reconcile(CReconcilingStrategy.java:63)
                   at org.eclipse.cdt.internal.ui.text.CompositeReconcilingStrategy.reconcile(CompositeReconcilingStrategy.java:87)
                   at org.eclipse.cdt.internal.ui.text.CCompositeReconcilingStrategy.reconcile(CCompositeReconcilingStrategy.java:90)
                   at org.eclipse.jface.text.reconciler.MonoReconciler.process(MonoReconciler.java:77)
                   at org.eclipse.cdt.internal.ui.text.CReconciler.process(CReconciler.java:349)
                   at org.eclipse.jface.text.reconciler.AbstractReconciler$BackgroundThread.run(AbstractReconciler.java:206)
!SUBENTRY 1 org.eclipse.cdt.core 4 969 2017-06-02 11:30:04.310
!MESSAGE Element (Project Name).c does not exist.
!ENTRY org.eclipse.cdt.ui 4 0 2017-06-02 11:31:32.746
!STACK 1
!SUBENTRY 1 org.eclipse.cdt.core 4 969 2017-06-02 11:31:32.746
!ENTRY com.crt.log 1 0 2017-06-02 11:35:33.501
!MESSAGE Drivers loaded in 5756 milliseconds
!SESSION 2017-06-02 15:38:59.919 -----------------------------------------------
!ENTRY org.eclipse.ui 4 4 2017-06-02 15:39:21.386
K.N> Error message did not show up after restarting LPCXPresso. Built seemed to be succeeded.  However, messages have been added to “log file” every time.  Following is the one of example. Would you advice its cause and countermeasures?
!SESSION 2017-06-02 16:40:40.234 -----------------------------------------------
!ENTRY org.eclipse.ui 4 4 2017-06-02 16:40:49.222
!ENTRY org.eclipse.cdt.make.core 4 0 2017-06-02 16:51:33.281
!MESSAGE Error accessing scanner config file for project
!STACK 1
org.eclipse.core.runtime.CoreException: Error accessing scanner config file for project
                   at org.eclipse.cdt.make.internal.core.scannerconfig.DiscoveredScannerInfoStore.saveDiscoveredScannerInfoToState(DiscoveredScannerInfoStore.java:306)
                   at org.eclipse.cdt.make.internal.core.scannerconfig.DiscoveredPathManager.updateDiscoveredInfo(DiscoveredPathManager.java:255)
                   at com.crt.advproject.specs.CRTPerProjectSICollector.updateScannerConfiguration(CRTPerProjectSICollector.java:77)
                   at org.eclipse.cdt.build.internal.core.scannerconfig.jobs.CfgSCJobsUtil$2.run(CfgSCJobsUtil.java:144)
                   at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:42)
                   at org.eclipse.core.runtime.Platform.run(Platform.java:867)
                   at org.eclipse.cdt.build.internal.core.scannerconfig.jobs.CfgSCJobsUtil.updateScannerConfiguration(CfgSCJobsUtil.java:155)
                   at org.eclipse.cdt.build.core.scannerconfig.ScannerConfigBuilder.build(ScannerConfigBuilder.java:210)
                   at org.eclipse.cdt.build.core.scannerconfig.ScannerConfigBuilder.build(ScannerConfigBuilder.java:154)
                   at org.eclipse.cdt.build.core.scannerconfig.ScannerConfigBuilder.build(ScannerConfigBuilder.java:120)
                   at org.eclipse.core.internal.events.BuildManager$2.run(BuildManager.java:734)
                   at org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:205)
                   at org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:245)
                   at org.eclipse.core.internal.events.BuildManager$1.run(BuildManager.java:300)
                   at org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:303)
                   at org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:262)
                   at org.eclipse.core.internal.events.BuildManager.build(BuildManager.java:402)
                   at org.eclipse.core.internal.resources.Project$1.run(Project.java:556)
                   at org.eclipse.core.internal.resources.Workspace.run(Workspace.java:2241)
                   at org.eclipse.core.internal.resources.Project.internalBuild(Project.java:534)
                   at org.eclipse.core.internal.resources.Project.build(Project.java:111)
                   at com.crt.ctrlcenter.launch.BuildUtils.buildProjects(BuildUtils.java:163)
                   at com.crt.ctrlcenter.launch.BuildUtils.access$0(BuildUtils.java:156)
                   at com.crt.ctrlcenter.launch.BuildUtils$2.run(BuildUtils.java:137)
                   at org.eclipse.core.internal.jobs.Worker.run(Worker.java:55)
Caused by: java.io.FileNotFoundException: C:\Users\(User Name)\Documents\LPCXpresso_8.2.0_647\workspace\(Workspace)\.metadata\.plugins\org.eclipse.cdt.make.core\lpc_chip_43xx.sc (The requested operation cannot be performed on a file with a user-mapped section open.。)
                   at java.io.FileOutputStream.open0(Native Method)
                   at java.io.FileOutputStream.open(FileOutputStream.java:270)
                   at java.io.FileOutputStream.<init>(FileOutputStream.java:213)
                   at java.io.FileOutputStream.<init>(FileOutputStream.java:162)
                   at org.eclipse.cdt.make.internal.core.scannerconfig.DiscoveredScannerInfoStore.saveDiscoveredScannerInfoToState(DiscoveredScannerInfoStore.java:302)
                   ... 26 more
!SUBENTRY 1 org.eclipse.cdt.make.core 4 -1 2017-06-02 16:51:33.281
!STACK 0
java.io.FileNotFoundException: C:\Users\(User Name)\Documents\LPCXpresso_8.2.0_647\workspace\(Workspace)\.metadata\.plugins\org.eclipse.cdt.make.core\lpc_chip_43xx.sc (The requested operation cannot be performed on a file with a user-mapped section open.)
!ENTRY org.eclipse.cdt.make.core 4 0 2017-06-02 16:51:45.278
!STACK 1
Caused by: java.io.FileNotFoundException: C:\Users\(User Name)\Documents\LPCXpresso_8.2.0_647\workspace\(Workspace)\.metadata\.plugins\org.eclipse.cdt.make.core\(Workspace).sc (The requested operation cannot be performed on a file with a user-mapped section open.)
                   ... 26 more
!SUBENTRY 1 org.eclipse.cdt.make.core 4 -1 2017-06-02 16:51:45.278
!STACK 0
!ENTRY com.crt.log 1 0 2017-06-02 16:52:48.659
!MESSAGE Drivers loaded in 1137 milliseconds
!ENTRY org.eclipse.cdt.make.core 4 0 2017-06-02 16:53:31.743
!STACK 1
                   at com.crt.ctrlcenter.launch.BuildUtils.buildProject(BuildUtils.java:145)
                   at com.crt.ctrlcenter.launch.BuildLaunchUtils.buildProject(BuildLaunchUtils.java:190)
                   at com.crt.ctrlcenter.launch.BuildLaunchUtils.buildWithProgress(BuildLaunchUtils.java:1325)
                   at com.crt.ctrlcenter.launch.BuildLaunchUtils.access$0(BuildLaunchUtils.java:1309)
                   at com.crt.ctrlcenter.launch.BuildLaunchUtils$4.run(BuildLaunchUtils.java:1264)
                   at org.eclipse.jface.operation.ModalContext$ModalContextThread.run(ModalContext.java:119)
Caused by: java.io.FileNotFoundException: C:\Users\(User Name)\Documents\LPCXpresso_8.2.0_647\workspace\(Workspace)\.metadata\.plugins\org.eclipse.cdt.make.core\lpc_chip_43xx.sc (The requested operation cannot be performed on a file with a user-mapped section open.)
                   ... 29 more
!SUBENTRY 1 org.eclipse.cdt.make.core 4 -1 2017-06-02 16:53:31.743
!STACK 0
lpcxpresso_supp
Hi Nakajima,
could you please try to:
  1. change the locale of your machine to en_EN and reboot;
  2. launch the LPCXpresso IDE using the command line prompt by adding the option "-clean"
  3. create a new workspace and import the projects
Please let us know.
LPCXpresso Support
lpcxpresso_supp
That last message is harmless and can be ignored. I presume the IDE is now working for you and building/debugging your projects ?
LPCXpresso Support
kennakajima
Understood.  Thank you for your reply.
Nakajima
kennakajima
Thanks for your response and following is my comment.
This (2017/06/02 16:24) is the first time I got an error on start-up.
I tried what you said but the error message was recorded in ".log file" in both cases below.
- New work space
- Importing existing project
Attached is ".log file" in the case of new work space.
Please advise.
Nakajima
lpcxpresso_supp
Hi Nakajima,
Please let us know.
LPCXpresso Support
kennakajima
Hello LPCXPresso support,
I have tried the operation told.
As a result, the number of messages has been decreased in both cases, the case creating a new work space and the case importing the project.
However, following message still remains:
Please take a look at ".log" file (the case a new work space created).
Nakajima
lpcxpresso_supp
Please start the IDE with a completely fresh workspace (i.e. not the one containing your projects), and see if it starts up successfully without error. If it does, please import some example projects (from the Examples folder of your IDE install) and see if they build successfully.
Please let us know the results.
Can you also zip up and post the actual .log file from the .metadata folder of your original workspace.
LPCXpresso Support
jeremyzhou
the opportunity to serve you.
I'd like to know when the error message first happen, and whether to try again after changing the Workspace.
TIC
