Eclipse including type.h
Content originally posted in LPCWare by Carsten on Sat Oct 08 05:08:24 MST 2011
I've try to run the example for RTC with an 1769 but the compiler always told that "type.h" can not be found.
What I have to change so that the compiler can find the header files.
Many thanks for your help.
Carsten
[IMG]http://s14.directupload.net/file/d/2671/u3e84uow_png.htm[/IMG]
Content originally posted in LPCWare by Ex-Zero on Sat Oct 08 05:52:31 MST 2011
Don't know if we are talking about the same sample :confused:
A good point to start is to check Includes and Libraries in your project settings :)
Note: Some samples use  a different CMSIS: "${workspace_loc:/CMSISv2_LPC17xx/inc}"
See also: http://knowledgebase.nxp.com/showthread.php?t=2326
