Delete Key stops working
Content originally posted in LPCWare by capstone on Fri Jul 11 16:41:08 MST 2014
LPCXpresso v7.2.0 (Build 153) - Win 7-64 - LPC175x-6x - LPC Open v2.10
Sometimes while performing many edits, the DELETE key stops working.
When this happens, the Right Click/Cut still functions normally.
I have noticed this with v6.1 as well, but do not recall this issue with the Code Red v5 IDE.
A Restart of the Workspace does restore the DELETE key functions.
Has anyone else noticed this behavior?
Content originally posted in LPCWare by PJanhonen on Sun Aug 24 11:54:52 MST 2014
Thanks that was it.
Restore defaults in Preferences-General-Keys window solves problem.
Content originally posted in LPCWare by lpcxpresso-support on Sat Aug 23 08:45:55 MST 2014
Have you changed any key bindings? Perhaps accidentally?
Content originally posted in LPCWare by PJanhonen on Fri Aug 22 02:03:23 MST 2014
No.
Restarting IDE or whole PC not fix the problem.
Content originally posted in LPCWare by lpcxpresso-support on Fri Aug 22 01:52:53 MST 2014
Does restarting, as mentioned by the original poster, 'fix' the issue for you too?
LPCXpresso Support
Content originally posted in LPCWare by PJanhonen on Fri Aug 22 01:33:59 MST 2014
I have same problem.
I installed LPCXpresso v7.3.0 [Build 186] , but problem stays.
Delete key works well in notepad and others editors.
