Defaul Format Variables
Content originally posted in LPCWare by blasiis on Thu Apr 29 03:27:01 MST 2010
In the LPCXpresso, in debug mode, how can I set for all variables the hexadecimal format visualization ?
I need that the variables is every time visualizated in hexadecimal format.
Where  can I find this configuration ???
Content originally posted in LPCWare by CodeRedSupport on Thu Apr 29 17:25:05 MST 2010
Please look harder - it *is* there.
Content originally posted in LPCWare by blasiis on Thu Apr 29 08:04:49 MST 2010
Quote: CodeRedSupport
Goto Window -> Preferences -> C/C++ -> Debug
Change "Default variable format" drop down box value from "Natural" to "Hexadecimal".
The change will only affect new variables added to the variables view. You will have to manually change variables already displayed (using the context menu "format" entry), or remove them and add them back again.
CodeRedSupport.
Thanks , I do  not find him !!!!
Content originally posted in LPCWare by CodeRedSupport on Thu Apr 29 07:04:36 MST 2010
Window->Preferences, C/C++ -> Debug, "Default variable format"
Content originally posted in LPCWare by CodeRedSupport on Thu Apr 29 07:03:54 MST 2010
CodeRedSupport.
