Debug not working on linux
851件の閲覧回数
Content originally posted in LPCWare by oversc0re on Wed Mar 19 03:57:02 MST 2014
Hi!
I've recently installed  lpcxpresso on debian machine where I can not make the debug work. I am using lpcxpresso board with integrated LPC-link. On windows everything is working. On linux every time I press debug i get the following message: Error in services launch sequence arm-none-eabi-gdb: error while loading shared libraries: libncurses.so.5: cannot open shared object file: No such file or directory
Any help would be appreciated!
771件の閲覧回数
Content originally posted in LPCWare by lpcxpresso-support on Wed Mar 19 04:29:25 MST 2014
You could start by reading the Getting Started guide, which describes how to install on Linux...
You can find the Getting Started guide in your product (from the Help Menu), as PDF, or online at:
http://www.lpcware.com/system/files/LPCXpresso_User_Guide.pdf
