Configuration Wizard in CodeRed
877 次查看
lpcware
Content originally posted in LPCWare by yanvasilij on Tue Dec 06 02:47:17 MST 2011
I found interesting comment in system_LPC11xx.h: //-------- <<< Use Configuration Wizard in Context Menu >>> -----------------. Is it mean that there exist Configuration Wizard in Code Red. I know that it is in Keil, and it very useful. How to execute Configuration Wizard if it exists in Code red?
812 次查看
lpcware
Content originally posted in LPCWare by RA1981 on Tue Dec 13 03:04:04 MST 2011
I think it doesn't exist in CodeRed/LPCxpresso. They simply took the header file from Keil, that's all. I assume it's because Keil implemented CMSIS compatible header files very early.
Ralf
