Compiler crash/damaged?
3,422 次查看
Content originally posted in LPCWare by caprock on Fri Mar 25 12:41:41 MST 2011
Win 7/64 - Code Red 3.6.2
For an unknown reason the compiler seems to have sustained damage and I was wondering how best to restore the Code Red functions without losing all of my work spaces.
This is what I am getting:
[I]
**** Clean-only build of configuration Debug for project oled_periph ****
make clean
      0 [main] us 0 init_cheap: VirtualAlloc pointer is null, Win32 error 487
AllocationBase 0x0, BaseAddress 0x71110000, RegionSize 0xB0000, State 0x10000
C:\nxp\lpcxpresso_3.6\msys\bin\make.exe: *** Couldn't reserve space for cygwin's heap, Win32 error 0
**** Build of configuration Debug for project oled_periph ****
make all
[/I]
So far it doesn't seem to matter what files I try, or from which workspace. I have already done a power cycle.
Any ideas as to how to proceed?
Thanks all....
18 回复数
3,396 次查看
Content originally posted in LPCWare by caprock on Fri Mar 25 18:16:44 MST 2011
Thank You!
3,396 次查看
Content originally posted in LPCWare by Ex-Zero on Fri Mar 25 16:24:29 MST 2011
This problem has been described before:
http://support.code-red-tech.com/CodeRedWiki/VirtualAllocPointerNull
Note: My own PC showed this message suddenly, changing 'msys-1.0.dll' solved the problem.
3,396 次查看
Content originally posted in LPCWare by Ex-Zero on Fri Mar 25 16:06:34 MST 2011
Try:
3,396 次查看
Content originally posted in LPCWare by Ex-Zero on Fri Mar 25 15:21:22 MST 2011
Try this:
3,396 次查看
Content originally posted in LPCWare by Ex-Zero on Fri Mar 25 15:13:22 MST 2011
Try:
3,396 次查看
Content originally posted in LPCWare by Ex-Zero on Fri Mar 25 14:39:02 MST 2011
Try:
3,396 次查看
Content originally posted in LPCWare by Ex-Zero on Fri Mar 25 14:06:02 MST 2011
Try:
3,396 次查看
Content originally posted in LPCWare by Ex-Zero on Fri Mar 25 13:51:32 MST 2011
Try:
3,396 次查看
Content originally posted in LPCWare by Ex-Zero on Fri Mar 25 13:40:24 MST 2011
Try:
3,396 次查看
Content originally posted in LPCWare by Ex-Zero on Fri Mar 25 13:28:40 MST 2011
Try:
3,396 次查看
Content originally posted in LPCWare by Ex-Zero on Fri Mar 25 13:22:09 MST 2011
Try:
3,396 次查看
Content originally posted in LPCWare by Ex-Zero on Fri Mar 25 13:10:12 MST 2011
Try:
3,396 次查看
Content originally posted in LPCWare by ex-kayoda on Fri Mar 25 13:01:56 MST 2011
Try:
3,396 次查看
Content originally posted in LPCWare by Ex-Zero on Fri Mar 25 12:57:05 MST 2011
Try this:
3,396 次查看
Content originally posted in LPCWare by ex-kayoda on Fri Mar 25 12:54:53 MST 2011
Try:
3,396 次查看
Content originally posted in LPCWare by Ex-Zero on Fri Mar 25 12:53:38 MST 2011
Try.
3,396 次查看
Content originally posted in LPCWare by Ex-Zero on Fri Mar 25 12:47:16 MST 2011
Try:
3,396 次查看
Content originally posted in LPCWare by Ex-Zero on Fri Mar 25 12:46:34 MST 2011
Try:
