Compiler/Linker warnings
Content originally posted in LPCWare by bhallett on Fri Oct 01 04:42:19 MST 2010
Hello All,
I have recently removed and re-installed LPCXpresso 3.3.4 (kept version for project compatibility) however ever since having done this I seem to always received the following warning:
Invalid project path: Include path not found (C:\!_ide\nxp\lpcxpresso_3.3.4_170\tools\arm-none-eabi\include).CMSISv1p30_LPC13xxpathentryPath Entry Problem
This does not seem to be causing any problems in the actual project itself but I would like to resolve the issue.
I cannot see anywhere where I can correct this problem, can anyone help ?
Barry
Content originally posted in LPCWare by CodeRedSupport on Fri Oct 01 05:55:35 MST 2010
Please see:
http://support.code-red-tech.com/CodeRedWiki/InvalidProjPath
CodeRedSupport
[B]
[/B]
