Cannot open LPCXPresso
2,528 次查看
Content originally posted in LPCWare by kaz on Wed Jun 04 20:06:34 MST 2014
I installed LPCXPresso ver 7.2.
Trying to open the application, alert dialog appears and it's not possible to open.
The alert dialog message is as below.
'An error has occurred.'
See the log file /Users/***/.eclipse/org.eclips.platform_4.3.2_77823396_macosx_cocoa_x86/configuration/1401936726949.log.
And the log is as below.
How should I do?
(I thought that the problem was java version and  installed 1.8.0, but still the same error has occurred.)
!SESSION 2014-06-04 19:29:21.003 -----------------------------------------------
eclipse.buildId=unknown
java.version=1.6.0_65
java.vendor=Apple Inc.
BootLoader constants: OS=macosx, ARCH=x86, WS=cocoa, NL=en_US
Framework arguments:  -keyring /Users/***/.eclipse_keyring -showlocation
Command-line arguments:  -os macosx -ws cocoa -arch x86 -keyring /Users/K00TSUKA/.eclipse_keyring -showlocation
!ENTRY org.eclipse.equinox.p2.core 4 0 2014-06-04 19:29:22.265
!MESSAGE Provisioning exception
!STACK 1
org.eclipse.equinox.p2.core.ProvisionException: Unknown repository type at file:/Users/***/.eclipse/org.eclipse.platform_4.3.2_77823396_macosx_cocoa_x86/configuration/org.eclipse.osgi/bundles/173/data/listener_1925729951/.
at org.eclipse.equinox.internal.p2.repository.helpers.AbstractRepositoryManager.fail(AbstractRepositoryManager.java:395)
at org.eclipse.equinox.internal.p2.repository.helpers.AbstractRepositoryManager.doCreateRepository(AbstractRepositoryManager.java:284)
at org.eclipse.equinox.internal.p2.metadata.repository.MetadataRepositoryManager.createRepository(MetadataRepositoryManager.java:41)
at org.eclipse.equinox.internal.provisional.p2.directorywatcher.RepositoryListener.initializeMetadataRepository(RepositoryListener.java:109)
at org.eclipse.equinox.internal.provisional.p2.directorywatcher.RepositoryListener.<init>(RepositoryListener.java:59)
at org.eclipse.equinox.internal.p2.reconciler.dropins.DropinsRepositoryListener.<init>(DropinsRepositoryListener.java:82)
at org.eclipse.equinox.internal.p2.reconciler.dropins.Activator.watchDropins(Activator.java:539)
at org.eclipse.equinox.internal.p2.reconciler.dropins.Activator.start(Activator.java:172)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl$1.run(BundleContextImpl.java:711)
at java.security.AccessController.doPrivileged(Native Method)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.startActivator(BundleContextImpl.java:702)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.start(BundleContextImpl.java:683)
at org.eclipse.osgi.framework.internal.core.BundleHost.startWorker(BundleHost.java:381)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.resume(AbstractBundle.java:390)
at org.eclipse.osgi.framework.internal.core.Framework.resumeBundle(Framework.java:1176)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.resumeBundles(StartLevelManager.java:559)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.resumeBundles(StartLevelManager.java:544)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.incFWSL(StartLevelManager.java:457)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.doSetStartLevel(StartLevelManager.java:243)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.dispatchEvent(StartLevelManager.java:438)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.dispatchEvent(StartLevelManager.java:1)
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230)
at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:340)
!SUBENTRY 1 org.eclipse.equinox.p2.metadata.repository 4 1005 2014-06-04 19:29:22.266
!MESSAGE Unknown repository type at file:/Users/***/.eclipse/org.eclipse.platform_4.3.2_77823396_macosx_cocoa_x86/configuration/org.eclipse.osgi/bundles/173/data/listener_1925729951/.
!ENTRY org.eclipse.equinox.p2.reconciler.dropins 4 0 2014-06-04 19:29:22.268
!MESSAGE FrameworkEvent ERROR
!STACK 0
org.osgi.framework.BundleException: Exception in org.eclipse.equinox.internal.p2.reconciler.dropins.Activator.start() of bundle org.eclipse.equinox.p2.reconciler.dropins.
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.startActivator(BundleContextImpl.java:734)
Caused by: java.lang.IllegalStateException: Could not create metadata repository for: file:/Users/***/.eclipse/org.eclipse.platform_4.3.2_77823396_macosx_cocoa_x86/configuration/org.eclipse.osgi/bundles/173/data/listener_1925729951/
at org.eclipse.equinox.internal.provisional.p2.directorywatcher.RepositoryListener.initializeMetadataRepository(RepositoryListener.java:112)
... 12 more
Root exception:
!ENTRY org.eclipse.osgi 4 0 2014-06-04 19:29:22.402
!MESSAGE Application error
!STACK 1
org.osgi.service.application.ApplicationException: No application id has been found.
at org.eclipse.equinox.internal.app.EclipseAppContainer.startDefaultApp(EclipseAppContainer.java:262)
at org.eclipse.equinox.internal.app.MainApplicationLauncher.run(MainApplicationLauncher.java:29)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:110)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:79)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:354)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:181)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
at java.lang.reflect.Method.invoke(Method.java:597)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:636)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:591)
at org.eclipse.equinox.launcher.Main.run(Main.java:1450)
8 回复数
2,495 次查看
Content originally posted in LPCWare by bkbaldwin62 on Fri Jul 18 02:41:32 MST 2014
Installing Java for OSX 2014-001 did the trick.
Thanks !!
2,495 次查看
Content originally posted in LPCWare by lpcxpresso-support on Wed Jul 16 00:59:31 MST 2014
You might want to take a look at this:
http://stackoverflow.com/questions/19563766/eclipse-kepler-for-os-x-mavericks-request-java-se-6
Especially the entry that refers to this link (about 2/3 of the way down the above page):
http://support.apple.com/kb/dl1572
Note that LPCXpresso v7 is based on Eclipse Kepler.
2,495 次查看
Content originally posted in LPCWare by bkbaldwin62 on Tue Jul 15 14:54:47 MST 2014
java version "1.7.0_60"
Java(TM) SE Runtime Environment (build 1.7.0_60-b19)
Java HotSpot(TM) 64-Bit Server VM (build 24.60-b09, mixed mode)
2,495 次查看
Content originally posted in LPCWare by lpcxpresso-support on Tue Jul 15 07:59:56 MST 2014
What does java -version report?
2,495 次查看
Content originally posted in LPCWare by bkbaldwin62 on Tue Jul 15 07:12:36 MST 2014
I get this same error but I am using version 1.7 of Java::
The JVM shared library "/Library/Java/JavaVirtualMachines/jdk1.7.0_60.jdk/Contents/Home/bin/../jre/lib/server/libjvm.dylib"
does not contain the JNI_CreateJavaVM symbol.
I am running Mac OSX 10.9.4 and only have Java 1.7 installed. I've tried running version 7.1.1, 7.2 and 7.3 of LPCXpresso and they all give me this same error.
I modified the info.plist for java to include the following:
          JVMCapabilities
                        CommandLine
                        JNI
                        BundledApp
                        WebStart
                        Applets
After doing this my version of Eclipse (Juno) runs just fine but LPCXpresso will not. Any ideas on what to do to get LPCXpresso working?
2,495 次查看
Content originally posted in LPCWare by kaz on Thu Jun 05 12:27:24 MST 2014
By the way, I just tried to install and run version 7.1.1 of LPCXpresso. It works.
It seems that this problem is on the newestversion..?
2,495 次查看
Content originally posted in LPCWare by kaz on Thu Jun 05 11:42:48 MST 2014
Thank you for your advice.
Here is the progress so far.
1. I added
"-vm
/Library/Java/JavaVirtualMachines/jdk1.8.0_05.jdk/Contents/Home/bin/java"
into ../lpcxpresso.app/Contents/MacOS/lpacpresso.ini file.
2. The previous alert has not appeared anymore. However, new alert message has been shown.
The message is as below.
The JVM shared library "/Library/Java/JavaVirtualMachines/jdk1.8.0_05.jdk/Contents/Home/bin/../jre/lib/server/libjvm.dylib"
3. Googled the message and people says that reinstall of Java for Mac OSX is needed. I tried it but nothing has changed..
I would appreciate if you can give any solution.
2,495 次查看
Content originally posted in LPCWare by lpcxpresso-support on Wed Jun 04 23:13:36 MST 2014
This sounds like a java version problem as we require v1.7 at least.
Although you have installed v1.8 you also need to make sure it is actually the default. Typing java -version into a terminal will tell you. If it not, then you need to switch the default (use google to find out how)
Alternatively, you can also define which jre to use in LPCXpresso. See
http://wiki.eclipse.org/Eclipse.ini
(Replacing eclipse with LPCXpresso)
