Can't start IDE any more :(
Content originally posted in LPCWare by martinjm on Mon Mar 08 01:08:11 MST 2010
It was all going reasonably well - Win7 x64 dual-core Ultimate plus the Virtual PC Win XP fix to get the LPC-Link USB link working.  Standard brand new LPCXpresso 1343. Was even making mods to/debugging Blinky to find my feet...
Now I can't start the IDE any more - just get a dialog box pointing me at my Documents\lpcxpresso_3.2\workspace\.metadata\.log which contains as below.
I had a problem with two (DFU-related? - can't remember exactly, the process names weren't intuitive) tasks running in Win7 - they were each using 100% of each core so I had to kill them with Task Manager. Then the problem started...
Tried re-installing, un-installing/re-installing, re-booting etc.  No joy.  Don't think it's anything to do with USB drivers - it just won't start the IDE at all.
Currently stuck and unable to proceed...:mad:
Quote:
!ENTRY org.eclipse.osgi 4 0 2010-03-08 07:58:04.542
!MESSAGE Application error
!STACK 1
java.lang.NoClassDefFoundError: org/eclipse/core/resources/IContainer
    at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:114)
    at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:194)
    at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:110)
    at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:79)
    at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:368)
    at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:179)
    at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
    at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
    at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
    at java.lang.reflect.Method.invoke(Unknown Source)
    at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:559)
    at org.eclipse.equinox.launcher.Main.basicRun(Main.java:514)
    at org.eclipse.equinox.launcher.Main.run(Main.java:1311)
Caused by: org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter$TerminatingClassNotFoundException: An error occurred while automatically activating bundle org.eclipse.core.resources (71).
    at org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter.postFindLocalClass(EclipseLazyStarter.java:125)
    at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLocalClass(ClasspathManager.java:449)
    at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.findLocalClass(DefaultClassLoader.java:211)
    at org.eclipse.osgi.internal.loader.BundleLoader.findLocalClass(BundleLoader.java:381)
    at org.eclipse.osgi.internal.loader.SingleSourcePackage.loadClass(SingleSourcePackage.java:33)
    at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:454)
    at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:410)
    at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:398)
    at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loadClass(DefaultClassLoader.java:105)
    at java.lang.ClassLoader.loadClass(Unknown Source)
    at java.lang.ClassLoader.loadClassInternal(Unknown Source)
    ... 13 more
Caused by: org.osgi.framework.BundleException: Exception in org.eclipse.core.resources.ResourcesPlugin.start() of bundle org.eclipse.core.resources.
    at org.eclipse.osgi.framework.internal.core.BundleContextImpl.startActivator(BundleContextImpl.java:806)
    at org.eclipse.osgi.framework.internal.core.BundleContextImpl.start(BundleContextImpl.java:755)
    at org.eclipse.osgi.framework.internal.core.BundleHost.startWorker(BundleHost.java:352)
    at org.eclipse.osgi.framework.internal.core.AbstractBundle.start(AbstractBundle.java:280)
    at org.eclipse.osgi.framework.util.SecureAction.start(SecureAction.java:408)
    at org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter.postFindLocalClass(EclipseLazyStarter.java:111)
    ... 23 more
Caused by: org.eclipse.core.internal.dtree.ObjectNotFoundException: Tree element '/LPCXpresso1343_blinky/LPCXpresso1343_blinky (Debug).launch' not found.
    at org.eclipse.core.internal.dtree.AbstractDataTree.handleNotFound(AbstractDataTree.java:257)
    at org.eclipse.core.internal.dtree.DeltaDataTree.getData(DeltaDataTree.java:585)
    at org.eclipse.core.internal.dtree.DataDeltaNode.asBackwardDelta(DataDeltaNode.java:50)
    at org.eclipse.core.internal.dtree.NoDataDeltaNode.asBackwardDelta(NoDataDeltaNode.java:59)
    at org.eclipse.core.internal.dtree.DataDeltaNode.asBackwardDelta(DataDeltaNode.java:47)
    at org.eclipse.core.internal.dtree.DeltaDataTree.asBackwardDelta(DeltaDataTree.java:88)
    at org.eclipse.core.internal.dtree.DeltaDataTree.reroot(DeltaDataTree.java:816)
    at org.eclipse.core.internal.dtree.DeltaDataTree.reroot(DeltaDataTree.java:815)
    at org.eclipse.core.internal.dtree.DeltaDataTree.reroot(DeltaDataTree.java:792)
    at org.eclipse.core.internal.watson.ElementTree.immutable(ElementTree.java:517)
    at org.eclipse.core.internal.resources.SaveManager.restore(SaveManager.java:670)
    at org.eclipse.core.internal.resources.SaveManager.startup(SaveManager.java:1353)
    at org.eclipse.core.internal.resources.Workspace.startup(Workspace.java:1957)
    at org.eclipse.core.internal.resources.Workspace.open(Workspace.java:1716)
    at org.eclipse.core.resources.ResourcesPlugin.start(ResourcesPlugin.java:379)
    at org.eclipse.osgi.framework.internal.core.BundleContextImpl$1.run(BundleContextImpl.java:783)
    at java.security.AccessController.doPrivileged(Native Method)
    at org.eclipse.osgi.framework.internal.core.BundleContextImpl.startActivator(BundleContextImpl.java:774)
    ... 28 more
EDIT: the spaces in the above aren't in my posting - don't know why they're showing up...
Content originally posted in LPCWare by martinjm on Mon Mar 08 02:22:40 MST 2010
Yep - all seems good now.  Thanks for the speedy response.
I'll put it down to 'one of those things' - I hope ;)
Content originally posted in LPCWare by CodeRedSupport on Mon Mar 08 01:18:18 MST 2010
It looks like you workspace is causing the problem (especially as you get the same error after re-installing).
So, create a new workspace (you get the chance on startup). You can the use:
File->Import
General
Existing projects into workspace
To import the projects from you old workspace into you new workspace.
