CRP - Code Read Protection Tips
919 次查看
Content originally posted in LPCWare by larryvc on Sat Apr 30 02:21:26 MST 2011
The following was a post by CodeRedSupport about CRP (Code Read Protection).  It provides several  links to the CodeRedWiki containing information about CRP and I found the content there to be very informative.
http://knowledgebase.nxp.com/showpost.php?p=7827&postcount=12
The thread it's from also has other good information about CRP.
863 次查看
Content originally posted in LPCWare by NXP_USA on Mon May 02 09:54:09 MST 2011
Hi Larry,
Thanks for pointing this out. There are also application notes NXP has detailing what CRP is, and why people may want to use it.
For LPC11xx/13xx:
http://ics.nxp.com/support/documents/microcontrollers/pdf/an10968.pdf
For LPC17xx:
http://ics.nxp.com/support/documents/microcontrollers/zip/an10851.zip
