C compiler information
1,566 次查看
Content originally posted in LPCWare by giamby3000 on Fri Jul 29 06:49:00 MST 2011
Hi!
How can I find C compiler  information used iin LPCXXpresso?
In particular I would like to know data types representations like these:
int : how many bits ?
char
unsigned char
long?
uint32 ect...  ?
With other compilers for 8 / 16 bit uP I can make an asm call for example
__asm NOP
How can use this instruction in LPCXpresso / GNU GCC compiler?
How can I find these informations?
Thank you very much and sorry for my basic questions!
:confused::confused::D
4 回复数
1,463 次查看
Content originally posted in LPCWare by giamby3000 on Fri Jul 29 07:33:23 MST 2011
Quote: Zero
Compiler:
Try GNU online doc:
http://gcc.gnu.org/onlinedocs/gcc-4.3.3/gcc/
Basic C questions:
A good C book or Wiki:
http://en.wikipedia.org/wiki/C_variable_types_and_declarations
NOP:
Use LPCXpresso file search function: CTRL-H, enter NOP and you can see where it's defined :)
I have already seen LPCX help for NOP, but if I write __asm NOP I have a compile error...
I know C language, but you teach me that compilers are different as implementation.. or not?
As this link: http://gcc.gnu.org/onlinedocs/gcc-4.3.3/gcc/
I have already found this link, but I don't find data types description. not at all, I'll find it sooner or later...
Thank you very much
1,463 次查看
Content originally posted in LPCWare by giamby3000 on Fri Jul 29 07:22:07 MST 2011
For ROB65:
Thank you very much for your answer!:mad::mad::mad:
Now all thinks are more clear!
Thank you!
Have a nice day!
1,463 次查看
Content originally posted in LPCWare by Rob65 on Fri Jul 29 07:06:17 MST 2011
Quote: Zero
Try GNU online doc:
Oh Cool :D
May i now ask G's next question for him ...
I can't find " LPCXpresso"  in this GNU manual, where should I look? :eek:
He could of course just use the #include "LPC13xx.h" file and use types like uint8_t, int16_t etc.
I'll leave it up to G to figure out how many bits are being used by these types :rolleyes:
G, just check the example projects. There are some nice examples of inline assembly in those projects.
Rob
1,463 次查看
Content originally posted in LPCWare by Ex-Zero on Fri Jul 29 07:00:57 MST 2011
Compiler:
Try GNU online doc:
Basic C questions:
NOP:
