Building projects from the command line (hang fix)
brich
This is not a question, rather it is a comment related to:Building projects from the command line
For those that experience apparent hanging of LPCXpresso after building from the command line, you may be having a problem related to the indexer.  The symptom looks like this on a console:
17:53:23 Build Finished (took 93s.270ms)
 <----Hangs here for a while before returning to console below
C:\bamboo\embedded\
The fix for this problem can be found in the following link: c++ - Java deadlock with Eclipse CDT headless build - Stack Overflow
In case the link above goes dead, try adding the -no-indexer option to the command you pass to lpcxpresso(c).  Your script should return immediately after the statement:
"17:53:23 Build Finished (took 93s.270ms)"
Happy automated building!
Labels (2)
