Breakpoint attribute problem: installation failed
2,221件の閲覧回数
Content originally posted in LPCWare by fjrg76 on Thu Nov 22 22:16:04 MST 2012
This problem started suddenly from one debug session to another:
[I][B]Breakpoint attribute problem: installation failed[/B][/I]
I cannot set breakpoints, although I've been working only with the "debug" release.
It seems to be a problem in the Eclipse's latest release, Indigo. And it also seems to be not fixed so far.
Any ideas?
3 返答(返信)
1,662件の閲覧回数
Content originally posted in LPCWare by CodeRedSupport on Sun Nov 25 03:30:56 MST 2012
Quote: fjrg76
This is known problem. The first time it was showed I googled it and I found some workarounds:
Google: Breakpoint attribute problem: installation failed
Aproximadamente 361,000 resultados (0.16 segundos)
It is a known *error message*, but not a known *problem*. From looking through the top hits, AFAICT, they were all due to user misunderstandings, or user error. I can't see ANY that are due to an error in Eclipse.
1,662件の閲覧回数
Content originally posted in LPCWare by fjrg76 on Sat Nov 24 22:00:31 MST 2012
I'll wait for the problem to show itself again so I can ask all your questions. Meanswhile:
Quote: CodeRedSupport
This is not a known problem. Can you please tell try removing ALL breakpoints in the Breakpoint view, and then recreating them.
Quote:
If this does not help, please try to provide as much information as possible on how to reproduce. For example
- how are you building your application? Are you using Debug or Release?
I was using "Debug"
Quote:
- In your workspace, do you have several files with the same name?
Just one main.c
Quote:
- How are you setting the breakpoints?
Double click in the left margin of the source editor.
Quote:
- Can you post the contents of the 'gdb traces' Console?
ASAP the problem shows up I'll do it, and also I'll try to send you all the information I can gather.
Quote:
BTW: The latest release of Eclipse is Juno (not Indigo) and LPCXpresso v5 is based on Juno.
My mistake :D
1,662件の閲覧回数
Content originally posted in LPCWare by CodeRedSupport on Fri Nov 23 02:24:20 MST 2012
