Assembler, inlude binary file at fixed destination
881 次查看
Content originally posted in LPCWare by kisiel on Mon Nov 11 05:36:06 MST 2013
Hello again.
I am trying to put binary file to location in the end of flash (for LPC1114 it will be last sector of 32K).
I have already tried .incbin "../src/ "  + ofset  but it is not working as I want.
Is there possible way to put 256B in last sector of Flash without using external tools ??
Thanks in advance.
860 次查看
Content originally posted in LPCWare by kisiel on Tue Nov 12 15:03:00 MST 2013
OK, thanks for help !!!
But finally everything is working except memory content.
I put,
.section .charen  // charen $6000-$8000
.org 0
.align 4
.incbin "../src/chargen.bin"
and in memory after flash I have ff ff ff ff
860 次查看
Content originally posted in LPCWare by lpcxpresso-support on Mon Nov 11 06:47:02 MST 2013
If you are using LPCXpresso, please read this FAQ:
http://www.lpcware.com/content/faq/lpcxpresso/placing-data-address
The principle is the same for assembler users - place the data that you want to locate in a named section, and use that section name when placing your data at an absolute address.
