Any LPC1114-302 SPI Example code?
1,528 次查看
Content originally posted in LPCWare by 12345 on Wed May 18 23:50:52 MST 2011
I am beginner. Where can I find SPI example code for
  LPC1114? I did not see it on LPCxpresso example projects?
4 回复数
1,399 次查看
Content originally posted in LPCWare by Spencer on Wed Jun 22 07:59:33 MST 2011
How to send data from SPI by UART?
1,399 次查看
Content originally posted in LPCWare by Ex-Zero on Fri May 20 00:24:54 MST 2011
To show you that your EEPROM access failed :mad:
1,399 次查看
Content originally posted in LPCWare by 12345 on Thu May 19 22:44:25 MST 2011
Quote: Zero
Try SSP sample :)
  Tks:
  Can I know why in ssp.c?
  Forever loop?
   if ( timeout == MAX_TIMEOUT )
while ( 1 );
1,399 次查看
Content originally posted in LPCWare by Ex-Zero on Thu May 19 02:54:10 MST 2011
Try SSP sample :)
Quote:
[FONT=Arial][SIZE=2][FONT=Arial][SIZE=2]The SPI/SSP is a Synchronous Serial Port (SSP) controller capable of operation on a SPI...[/SIZE][/FONT]
[/SIZE][/FONT]
