16: target error from status-poll: Ee(4c) Fatal error
854件の閲覧回数
lpcware
Content originally posted in LPCWare by Vyshali on Thu Mar 05 01:24:11 MST 2015
While debugging my code using the LPC Link 2 board connected to my target, if I don't set a breakpoint and run my code I get 16: Target error from status-poll, ACK fault, if I set breakpoints to investigate, I get 16: target error from status-poll: Ee(4c) fatal error, after hitting a breakpoint. I have changed the debug board and the USB cable, I still get the same issue. If I run the code without debugger, the code doesn't crash, everything is fine. I don't understand why executing on the debugger causes issue. Any help?
731件の閲覧回数
lpcware
Content originally posted in LPCWare by lpcxpresso-support on Thu Mar 05 01:38:53 MST 2015
See this FAQ:
http://www.lpcware.com/content/faq/lpcxpresso/regaining-debug-access
