LPCxpresso1769 on stick EEPROM example
425 次查看
lpcware
Content originally posted in LPCWare by xjx on Fri Dec 11 15:52:19 MST 2015
I would like to have an example where the I2C EEPROM which is part of the LPCxpresso 1769 stick is used.
the I2C example provided with LPCopen examples is the closest I have found. However, as an actual EEPROM is soldered with the stick, I am sure somebody has done this before.
Please let me know.
thank you
Cmunikat
0 回复数
