15: Target error from Read Memory
1,689件の閲覧回数
lpcware
Content originally posted in LPCWare by tridentsx on Sun Oct 16 19:21:19 MST 2011
Dont know what happened to my LPC1769 xpresso, I cant flash new build to it, it does startup and run old s/w that has been flashed to it, but everytime I try to flash it with run or debug, the process seems to hang at 96% and then I get an error popup
  Not connected to emulator.
I had a problem with flashing it but found a fix on code red faq to enable vector catch, I did that once and I could flash the chip but after that I always get the described problem.:mad:
Please help if you have any idea what it could be.
Carl
1,245件の閲覧回数
lpcware
Content originally posted in LPCWare by tridentsx on Mon Oct 17 07:14:36 MST 2011
I used the trick described in this thread http://knowledgebase.nxp.com/showthread.php?t=1589
Now the board is functioning properly.
