Сolor theme LPCXpresso interface
lpcware
Content originally posted in LPCWare by Free Mind on Fri May 09 07:54:52 MST 2014
Hi!
Can't apply the color theme to the interface.
Followed the recommendations of the setup on this page. But failed.
I install Jeeeyul's Eclipse Themes and got a menu item, but the changes are not applied.
[img]https://github.com/jeeeyul/eclipse-themes/wiki/images/customize.png[/img]
Code Red has blocked the possibility to change the color of the interface?
lpcware
Content originally posted in LPCWare by Free Mind on Fri May 09 12:52:59 MST 2014
"resulting from NXP's acquisition of Code Red Technologies" (url)
I had Latest version of LPCXpresso IDE : v7.1.1
The changes are not applied from General > Appearance > Jeeeyul's Themes - only from Toolbar.
lpcware
Content originally posted in LPCWare by lpcxpresso-support on Fri May 09 08:30:00 MST 2014
Who are Code Red? There is only NXP now....
Anyway, that plugin works for me. See attachment, showing the IDE after applying  the "Cloud Space" theme.
