15: Target error from Register access: Ee(FF). Undocumented error.
2,876 次查看
lpcware-support
Senior Contributor I
Occasionally when terminating a debug connection, you may see an error message of the form:
The cause of this is under investigation for fixing in a future LPCXpresso IDE release. However this is a harmless error. If you OK the dialog, the debug connection will then complete termination correctly
标记 (3)
0 回复数
