15: Target error from Register access: Ee(FF). Undocumented error.
2,871件の閲覧回数
lpcware-support
Senior Contributor I
Occasionally when terminating a debug connection, you may see an error message of the form:
The cause of this is under investigation for fixing in a future LPCXpresso IDE release. However this is a harmless error. If you OK the dialog, the debug connection will then complete termination correctly
タグ(3)
0 返答(返信)
